noise on breaks
i hear a wierd gratting noise when i apply my breaks (more frequently when it rains/after it rains). i heard its just dust brakes and its common especially with cars equipped with abs - is this true? what about a high pitched noise when you apply your brakes? does it mean that your breaks are thin? thanks.
RE: noise on breaks
it means that your brake pads are getting low and will need to be changed soon. The put little pieces of metal in the pads purposly, that way when its low they make that noise telling you that they need to be changed.
RE: noise on breaks
If you hear a grating/grinding noise, you're cutting into the rotors. If its a high pitched squeek, it's time to change the pads or have the rotors re-surfaced.
RE: noise on breaks
Check your brake fluid. If it's low then your brake pads need to be replace.
RE: noise on breaks
do a visual to check your pad thickness. If it looks okay it may just be the brake dust you were told about. This is more and more common in the newer metalic pads that are sold today. My freind had brake noise that sounded like he needed new pads. His were okay. I soaked his pads with brake cleaner and had hime drive around the block while riding his breaks (twice) then his break noise went away. But thats only if our pads are still good.
RE: noise on breaks
ORIGINAL: NYC Civic Check your brake fluid. If it's low then your brake pads need to be replace. |
RE: noise on breaks
ORIGINAL: Super Mario ORIGINAL: NYC Civic Check your brake fluid. If it's low then your brake pads need to be replace. Edit: Man, I just looked back at that post and it is like FIVE MONTHS old!!! Death Before Decaf, pay attention to the dates on the thread before replying. Thanks. |
RE: noise on breaks
the fluid will be a little low because some of the fluid will be in the caliper holding the piston farther out. i dont know how reliable this is as a check though.
RE: noise on breaks
that difference is so miniscule.. you will lose more braking power from the brake line flex (on most stock cars) than if your pads were low... totally no need to worry about brake pressure drop from worn pads.
RE: noise on breaks
i dont think he meant pressure drop, its that the level will be a little lower because the fluid is in the calipers instead of the resevoir.
