o6 control arm question
I have a 06 4 door, it has always worn the rear tires on the inside. I just found out there was a tsb from honda, about this issue. I called the dealer, she said there was a control arm kit? $219 You would think if honda knows there is a problem they would just fix it. Any way how hard is the kit to install? dealers wants over $400 to do the whole job.
Do you have more info on the "kit"? I imagine it's a revised piece within the alignment parts, but could be something with the control arm bushing.
But if it involves replacing the bushing, it's a tough job. If not, it's probably a simple bolt-on affair. Does that $400 cost include a new alignment? |
I think it does.
