Outer Tie Rod Ends????
Old Nov 29, 2006 | 06:10 PM
burnindesirez02's Avatar
Default Outer Tie Rod Ends????
Does anybody know how to install Outer Tie Rod ends and CV-shafts(Halfshafts)? I need to get new ones. but don't want to pay 600 dollars to get it fixed.
Old Dec 3, 2006 | 12:50 AM
bigwill1384's Avatar
Default RE: Outer Tie Rod Ends????
yea outter tie rods are easy and the half shafts are a little bit harder its a little hard to explain how to do it ur best bet is buying the HAYNES repair manual and your local auto parts store those book come in handy. or go to autozone.com and u should be able to find out how to do it they have repair guids on there site
http://autozone.com/servlet/UiBroker...ginRepairGuide
Old Dec 3, 2006 | 01:05 AM
civicexracer's Avatar
i did a DIY on the axles. sent it to Patrick, just waiting for him to post it if he thinks its good. i could PM the DIY to u if u want?
Old Dec 12, 2006 | 08:55 PM
Yea i have the Haynes manual for my car and it doesn't say how to install half shafts but it does show tie rods. But yea send me the DIY of it. Thanks
Old Dec 12, 2006 | 09:03 PM
How long will the halfshafts last with broken CV boots? I might just do the outer tie end rods myself and then when i got the money i will get somebody to do the halfshafts if possible.
Old Dec 12, 2006 | 10:18 PM
SilverSedan's Avatar
Half-shafts can last a while, IF you drive nicely on them (aka gentle acceleration, esp around sharp corners). The bad news is they will continue to wear and make nasty noises as they do. Eventually, the CV joint will completely self-destruct, at which point your car is going nowhere, except onto the back of a tow truck and from there to a shop of your choice. A friend of mine drove almost a year with bad shafts before he replaced them...and had no issues. Another friend drove 2 months (during summer, so it was dry, no moisture getting into the joints) and they came apart on the freeway []
If you can at all afford to do it, do the half-shafts too...its safer
Lambo Civic
14
May 28, 2012 06:12 AM
Mecca8383
Apr 25, 2011 04:19 PM
Mecca8383
Jan 12, 2011 03:56 PM
mundy5
Jan 14, 2010 01:49 PM
burnindesirez02
Nov 29, 2006 09:23 PM
