Piston Rod top lug nut
Old Mar 7, 2008 | 07:58 PM
vertech0's Avatar
Default Piston Rod top lug nut
i hate to keep buggen about the lowering springs stuff, but i just read on the tein manual not to put the old lock nut back on the piston rod. if thats the cas, where can i find a new lock nut? and how strong dose it have to be?
thanks
Old Mar 7, 2008 | 08:57 PM
baron340's Avatar
Default RE: Piston Rod top lug nut
it should come with the struts, or at least mine did. if not just get the specs on the factory one and get another just like it. it should fit. you arent supposed to reuse lock nuts after they have been taken on and off multiple times because they lose their locking qualities.
Old Mar 7, 2008 | 09:17 PM
vertech0's Avatar
well, im only replacing the springs. not the struts/shocks.ill go to the honda dealer and get them from them.
thanks for your reply
Old Mar 8, 2008 | 12:28 PM
i just reused mine....
my threads looked good and felt tight so i just reused them...
but if you really want o rthink you need to replace them then go buy some from the dealership.... im sure they have some instock!
Old Mar 8, 2008 | 07:42 PM
vertech0's Avatar
ok thank you =)
Old Mar 12, 2008 | 08:49 AM
Kommando's Avatar
Price them at a hardware store first. Look at Grade 8.
Old Mar 12, 2008 | 11:57 AM
vertech0's Avatar
ok, ill check it out. thanks
tlkolrod
Jul 16, 2010 06:53 PM
mill$civic
Apr 13, 2006 09:59 AM
natecivic92
Feb 15, 2006 06:45 PM
nemo
Dec 9, 2005 09:10 PM
gpotski
Nov 27, 2005 08:01 PM
