Popping noise in front end ?
Old 08-05-2006, 12:45 PM
Dezrat's Avatar
Default Popping noise in front end ?
We have a popping noise on a stock 2004 Civic LX coupe. It sounds like the strut is shifting or binding. This happens when turning right or left. It doesn't sound like a CV joint. Any ideas or TSB's anyone knows would help. Thanks Dezrat
Old 08-05-2006, 01:33 PM
KarTuneMan's Avatar
Default RE: Popping noise in front end ?
Theres not alot to look at to inspect all of the front end parts. Strut bolts top, and bottom (@ the control arm) is the car lowered? check to make sure the srping is in the perch where it belongs, if not, when you turn it will spin and pop. Inspect the CV boots as well tie rod ends...they won't make much noise though.
http://www.indiacar.com/index2.asp?p...assis/chas.htm
Old 08-05-2006, 05:55 PM
Fiirkan's Avatar
could be the ball joint, my upper one is shot to **** and it always pops when i go over bumps, or when i turn somtimes
akoutdoors1
12
07-22-2011 05:51 PM
ahackett
04-05-2011 10:43 AM
jacksmash
11-03-2009 02:35 AM
tarboroheel1
09-22-2006 08:50 PM
Ben
08-07-2006 12:43 AM
Quick Reply: Popping noise in front end ?
