quick release for rear upper strut bar?
Old Apr 19, 2007 | 08:53 PM
snosurfa7's Avatar
Default quick release for rear upper strut bar?
Anybody rig up a quick-release for the upper rear strut bar, if they need to use the trunk to haul stuff?
I was thinking wing nuts...but since these are bolted onto the shock mounts I would think this would make any sort of quick-release system kind of hard, or at least a pain on a weekly basis...
thanks
Old Apr 19, 2007 | 08:57 PM
civicexracer's Avatar
Default RE: quick release for rear upper strut bar?
for the Bomz Racing one, u just use an allen key and wrench and within a minute u can pull the bar out. the mounting points are still attached to the car, but those dont take up any room in the trunk anyways..
Old Apr 19, 2007 | 08:58 PM
mill$civic's Avatar
I know the one I had before you just had to undo the bolts and the bar would come out but the mounts would stay there. It was by APC.
Old Apr 19, 2007 | 09:14 PM
snosurfa7's Avatar
Good to know...does anyone know if the ebay ones work this way too? The ones where you get the set of 4 for like 60 bucks?
Ok ok don't flame here on them I figure something is better than nothing, from whats on here they've appeared to get pretty decent reviews anyway, this is my DD on a budget so thats where I'm going hopefully...
thanks so far
Old Apr 19, 2007 | 09:15 PM
danomatic93's Avatar
June 2010 ROTM
There are tons on eBay, which ones? Don't worry, most people get theirs on eBay.
Old Apr 19, 2007 | 09:31 PM
snosurfa7's Avatar
http://cgi.ebay.com/ebaymotors/Strut...mZ260108032715
It looks like?? you could make just the bar quick release, and the mount stay, but a second opinion would be nice before I pick them up. I guess I could email the dude too, but they might not get the question...
Old Apr 19, 2007 | 09:53 PM
yes those will unscrew and the bar will come right out.
Old Apr 19, 2007 | 09:59 PM
you can make your own quick release preaty easily... just buy the good old ebay brace thats what i did... and then take the side piece to your local hardware store... and find some pins for them... not sure what ya realy call them but same type as a trailer hitch uses.. simple pin and then a cotter pin to hold the thing inplace....
hardest part will be finding a pin thats snug enough to work good.... or buy a pin thats alittle larger and drill the holes out to fit perfectly!!!!!!!
and thier ya go.... instead of a bolt and nut its a pin and cotter pin..
i got a ebay rear brace but i never used mine cause of my subwoofer box setup i built... i thought about cutting thru the box to mount the brace like it should... but just havent felt like touchen the setup at least until i buy my new amplifier
CrIyVaInC
Apr 16, 2008 11:32 PM
Nerosync
Suspension, Brakes, Wheels & Tires
Mar 15, 2008 06:00 PM
ej6buddy
Mar 21, 2007 08:52 PM
bigmikew1
Feb 27, 2007 12:26 PM
FlipHKD720
Aug 12, 2006 03:28 PM
