rear disc problem
i just got a rear disc conversion from a 96 teg. only thing that was missing were the e-brake cables. i went to a junk yard and got a set from a 2000 teg. i got it all together and it seems the the teg e-brake cables are abuot an inch too short. i routed it just like it came off the teg and bolted the brackets all in like they were supposed to be. any ideas?
RE: rear disc problem
loosen the adjuster on the e-brake handle as far as you can and have it still connected, then see if it fits. i remember those were a pain, but dont remember the specifics.
i just had to eliminate one bracket in the middle of each cable and got the slack i needed. it still seems pretty secure
ORIGINAL: PhilStubbs i just had to eliminate one bracket in the middle of each cable and got the slack i needed. it still seems pretty secure |
ORIGINAL: Kolhoznik ORIGINAL: PhilStubbs i just had to eliminate one bracket in the middle of each cable and got the slack i needed. it still seems pretty secure |
I'm gonna rock cheapo rotors and pads until spring...don't wanna crack a rotor in the snow...
damn, i never thought about that. that would suck
