rear drum to disc on a 95 civic VX hatch
im tryin to swap my stock rear drums to rear disc on my 1995 honda civic vx hatchback...what models can i get this conversion off of and what all do i need? any help would be greatly apprecaited...thankz
ORIGINAL: johnb
Will that application fit on my car? I'm considering doing the same thing. Does it make your car stop better? How much should this run $ wise?
http://store.summitracing.com/partde...p;autoview=sku
There you go
Edit: I would get a better set of front disc brakes, and just re-build the rear drum brakes.
The rear is only roughly 25% of your stopping anyway, that's a cheaper route.
I boguht a set of willwood front disc brakes from summitracing.com.
Completely worth it.
I was looking at rear disc brakes, and there aren't much for rears for these cars, the best disc brake kit you will find is what they basically use on stock Si's or SiR's.
There you go
if i use that kit from summitracing do i still have to change the master cylinder and the rest or will that kit work with the factory one? the main reason im changing to disc is im having alot of problems with the drums and i use my e-break alot...only way to drift a fwd...lol...
FanTasTicRidE
Oct 9, 2011 05:16 PM
