Rear LCA Bolts
Old Mar 7, 2007 | 11:01 AM
Nochek's Avatar
Default Rear LCA Bolts
I am going to replace my LCA's and my coilover system, and I dont want to use the bolts currently in there, since they tend to freeze and need to be cut out (pissy little things).
I was wondering if any bolt is acceptable for that rear part, or if there is a reason for what seems to be those poorly designed bolts.
If I need the OEM ones, is there anywhere I can order a set of 6 of them?
Old Mar 7, 2007 | 11:05 AM
mxs's Avatar
mxs
Default RE: Rear LCA Bolts
use the OEM bolts, they are very strong, I wouldn't run the risk of using something cheaper when it comes to holding my suspension to the chassis...
you can buy them here: http://www.hondaautomotiveparts.com/
Old Mar 7, 2007 | 11:13 AM
drbyers's Avatar
the reason you don't want to use Home Depot hardware-grade flange bolts is because they use "softer" metal that isn't reinforced and would fail catastraphically. that would suck on your part.
boiler1
Jun 9, 2011 06:18 PM
chase07
Nov 9, 2007 04:52 PM
snosurfa7
May 25, 2007 12:41 PM
civicexracer
Jul 19, 2006 04:48 AM
campbuds
Jul 6, 2006 07:42 AM
