Rear Upper Strut Mount Removal?
I made a post about a noise i get from rear passenger side wheel area when going over bumps.
I was guessing upper strut mounts and so did the shop i took it too. I want to remove the strut assemblys and check the mount. A couple questions though... 1. Does the mount require the spring to be removed? 2. If i replace 1 side, should i do both? 3. If i replace them, would i need to get a rear allignment? Thanks. JR |
