Removing Brake Calipers
I need help removing brake calipers on my 1993 Honda Civic.How do I remove them?Thankyou LU E.
RE: Removing Brake Calipers
if i am not mistaken, take the bottom caliper bolt out and the caliper should swing up. if you want to take the caliper off completely, swing it up and it should slide out towards the motor.
^ That is the correct procedure to remove the caliper. Don't forget to put greese on top bushing/bolt where you slid the caliper off. Also, greese should go on the edge of the pad where they rub on the caliper. Make sure you get the clips in correctly and in the right spots.
