REPLACEMENT SPRINGS
Old Nov 22, 2005 | 10:23 AM
leco516's Avatar
Default REPLACEMENT SPRINGS
What kind of springs would be best for a
civic hatchback, need to replace them any way,
variable ratio is what I've been looking at.
should I wait until I put new wheels on? it still
has 13 in. wheels. Should it be lowered with
17 in. wheels?
Old Nov 23, 2005 | 12:00 PM
x2100's Avatar
Default RE: REPLACEMENT SPRINGS
Eibach are good springs.. Sprint..
Yeah, I'd say drop and 17s will look nice
I didn't drop mine and it looks like the wheels are too small because there's so much wheel gap.
Old Dec 1, 2005 | 06:04 PM
leco516's Avatar
Yeah thanks....I have since learned that a two inch drop
is about right with the 17's. The reason I thought I didn't
want it lowered is because I'm 6'3" and getting in a civic so
low to the ground is a bit awkward. With 17 inch wheels
and a two inch drop the car will be sitting higher than it was,
how much I don't know. Maybe someone knows the roof
height with stock 13's and then with 17's lowered.
Old Dec 1, 2005 | 09:44 PM
ALX's Avatar
ALX
The concensus around here is that Tein S-techs are a good lowering spring for a decent price. Depending on what year hatchback you drive you can expect between 1.5~1.9" of drop. Neuspeed springs are good as well for more drop 2.0 ~ 2.5 but that's if you want an even more drastic drop.
If you go with 17s make sure you run a 205/40/17 tire with a really nice and strong sidewall to prevent damage to your wheel and that specific size tire to prevent rubbing.
Ramyswar
Feb 4, 2012 05:09 PM
SinisterCivic1
Mar 31, 2010 11:42 AM
tuong
Apr 27, 2008 02:35 PM
tuong
Apr 16, 2008 11:28 PM
sasquatch
May 25, 2007 04:02 PM
