rotor
wow is it just me or are the bolts for taking off the front rotors hard to get off. so my question is.. are there any tricks or something to taking those bad boys off or do you just need brute force to take them off
ORIGINAL: Roadkillboy0
If you're having trouble with a bolt, spray as close to the threads as possible with some PB Blaster and let it work. Then try an impact wrench. I wouldn't use just brute force because bolts can break or strip.
What year is your Civic? Mine is a 2001 and has two philips head screws holding the rotors in place. First you remove these screws usually with an impact driver and hammer. Next you will notice two additional threaded holes in the rotors, here you will insert two bolts and turn each a little at a time to get the rotor off the hub assembly.
billthepill
Jul 14, 2005 01:49 PM
Cleft_Asunder
Jun 27, 2005 03:52 PM
Oni_kage
Feb 19, 2005 01:35 PM
cvcman
Jan 17, 2005 08:25 PM
