Rustly Bolts
I wanted to take my strut bar off the paint the ends and I got one side of bolts off and the other sides refuse to come off and I don't want to risk breaking them so I spayed them with WD-40 and they still didn't move. Is there another thing that I could do to then to get them to come off, someone in the i/h/e forum said they soaked a rusty bolt in Pb blaster? overnight, Would that work and if it would where do I get pb blaster?
[IMG]local://upfiles/12015/E7A430B6FAC248C2B0160E98F3FC3952.jpg[/IMG] |
RE: Rustly Bolts
ya try PB Blaster. soak it real well and let it sit over night and soak it again. if that dosnt work, take a dremel to the nut...
RE: Rustly Bolts
yeah pb blaster SHOULD do the trick....you can get it at like an autozone type of store...good luck dude
RE: Rustly Bolts
that should come off with a 6 point socket and a long breaker bar. I wouldn't try cutting the nut off
RE: Rustly Bolts
if you have acces to a torch, a little heat on the bolt will help, but don't melt any wires.
RE: Rustly Bolts
Combine the last two suggestions and you'll be golden. Heat + Breaker Bar = smooth removal ;)
RE: Rustly Bolts
alright I try that this weekend thanks guys/
