HondaCivicForum.com
-   Suspension, Brakes, Tires & Wheels (https://www.hondacivicforum.com/forum/suspension-brakes-tires-wheels-14/)
-   -   Safe to cut a shock in half? (https://www.hondacivicforum.com/forum/suspension-brakes-tires-wheels-14/safe-cut-shock-half-95445/)
boiler1 Jun 23, 2013 03:08 PM
Maybe a stupid question, but can I take a sawsall across the shock (below the spring) without anything blowing up in my face? My front shock pinch bolts are seized and I was looking to save some time having to pull the axles.
kanarrjl Jun 23, 2013 08:21 PM
as long as the shock is fully extended I would say that it is completely safe.
boiler1 Jun 24, 2013 03:30 AM
Thought about it more, and I may just cut the forks. Problem is, there's still spring compression on there that the shock shaft is holding, even at full extension.
civicexracer Jul 10, 2013 08:15 AM
Not safe.. The shock is under pressure.
You don't need to remove the fork to remove the axles. Just drop the lower control arm.. If you really want to remove the pinch bolt, drill it out.
