Shocks/Suspension Compatibility
Old Oct 31, 2009 | 12:19 PM
doridori's Avatar
Cool Shocks/Suspension Compatibility
Hello,
I have a 1999 Civic EX 4-Door. Can it use the suspensions/shocks from other year/model of Civic and Integra? If so, where can I get the complete list of compatible models?
BTW, I am looking for the left and right rear suspension shock or suspension (my current ones are making some noise) for my car. Used parts with good condition are fine. I am just using this Civic as a commute car. I don't have to have performance parts. Please email me at tuner1212@gmail.com if you have any.
Thanks
Scott
Edit/Delete Message
Old Nov 1, 2009 | 09:32 AM
xero_xero's Avatar
the fronts are compatible 88-2000, rears not so sure about. there will be nominal differences between ride height and spring rate.
have plenty of oem stuff, located in atlanta.
Old Nov 1, 2009 | 11:02 AM
You an use 92-95 Civic rear shocks. The only difference is that the fork/bracket at the bottom of the shock is a little bit wider on the 92-95 shocks. Simply fill in that gap with washers.
I believe the fronts are nearly exactly the same, with some differences in the brake line brackets.
spintelect
May 17, 2007 04:23 PM
S_ense23
Feb 2, 2006 05:20 PM
Assasin
Dec 8, 2005 07:25 PM
Forty04
Nov 4, 2005 09:48 AM
00civiclx
Oct 18, 2004 09:55 PM
