Are Suspension Bushings hard to replace?
Are Suspension Bushings hard to replace? Those Energy Suspension bushings look nice, but what tools do you need to install them / remove the old bushings? Can these tools be rented from Autozone?
Did it make a diference in ride after you put them on? |
RE: Are Suspension Bushings hard to replace?
Are you replacing all the bushings or just some of them?
Anyway, it's not really hard (time consuming, but not really hard)... I did a write-up on the rear LCA/strut mount bushings; I'll see if I can't find it and get you a link... I'd think the process of replacing all the other bushings would be similar. *edit: found it ;) |
Wow, thanks for the link! That seems like a lot of work and it'd surely be expensive having a shop do it all so I guess I'll stay stock. Unless there are some easy ones I can do.
Any mod I can do myself - I'd probably do, as I hate paying $65 labor rates. Like my 6 Silicone coolant hoses took 2.5 hours = ~$170 labor. |
