Sway bar installation
Old Oct 17, 2007 | 12:16 PM
Everyday Getaway's Avatar
Default Sway bar installation
I just bought sway bars off of a 95 integra (both came with my rear disc conversion) but I'm not sure what hardware to get to put them on, or just how to install them. Will I need to get new bushings for the sway bar to go in properly... also, will the front sway bar even fit my car, for that matter, will the rear??? I drive a 97 sedan...
Old Oct 17, 2007 | 12:44 PM
mybrokenblinker's Avatar
Default RE: Sway bar installation
i'm pretty sure 94-01 integra bars will fit your car
what you'll need are endlinks and some kind of subframe brace if you're interested in making sure you prevent subframe tearout.
Old Oct 17, 2007 | 12:46 PM
civicexracer's Avatar
for the rear u'll need endlinks, d-brackets, bracket swaybar mountbushings, and hardware.
what model integra was this?
Old Oct 17, 2007 | 01:12 PM
yeah you won't need a subframe brace if it's one of the smaller bars
Old Oct 17, 2007 | 01:32 PM
The front one is thicker than the rear one, the rear one is really thin infact. The integra was a 95. Where can I find all the parts to install them? Thanks for all the help!
Old Oct 18, 2007 | 08:03 AM
yaes, the front one should be bigger than the rear if they are stock bars. That's honda's attempt at making sure you get plenty of understeer and no lift off oversteer.
brokenarmboy19
Suspension & Steering DIYs
May 27, 2007 11:29 PM
FlipHKD720
Aug 12, 2006 03:28 PM
D16z6
May 22, 2006 09:24 AM
dmsteele92831
Dec 29, 2004 06:26 PM
sonicOne
Oct 6, 2004 09:18 PM
