For those of you who stripped the LCA bolt/suspension job
Old Apr 26, 2007 | 05:03 PM
Default RE: For those of you who stripped the LCA bolt/suspension job
o ya... i had the same problem that with my struts bump stops/dust shields..... i had to work awhile on them till they would come off from those top bushing shafts! LOL
Old Apr 26, 2007 | 09:23 PM
snosurfa7's Avatar
Yeah, my civic bolts are going to be getting a bath in PB Blaster every night for a few days before I do the install!
How did yall get the stuck bump stops and all off the strut (or best way to)? Heat? Does PB work there too? Hammer? Or just kept wiggling them until they came off?
thanks
Old Apr 26, 2007 | 10:08 PM
civicexracer's Avatar
well pb blaster or any kinda of lubricant wont do jack on seized bolts so just save it for the other bolts. to take the spring off the strut, use a spring compressor. compress the spring so theres no pressureon the tophat.then take an allen key and wrench and take the tophat off the strut. once u get that top bolt off, everything will just come apart. the bump stop should just slide off the shaft.
Old Apr 27, 2007 | 01:44 PM
well if the steel bushing on the upper part sticks to the shaft simply take the allen wrench ontop and with a pair of vis grips jsut lock it onto it and just keep twisting back and forth.... and maybe alittle spray just for alittle lube.... and it should come off.... and if the washers stick to the shaft just hit them off with a screw driver or something...
megafandrew
Feb 16, 2008 06:03 PM
mrblades
Jul 9, 2007 04:35 PM
that_guy5
Dec 6, 2006 10:13 PM
rit14623
May 2, 2006 01:32 PM
mill$civic
Apr 13, 2006 09:59 AM
