HondaCivicForum.com
-   Suspension, Brakes, Tires & Wheels (https://www.hondacivicforum.com/forum/suspension-brakes-tires-wheels-14/)
-   -   tire rub (https://www.hondacivicforum.com/forum/suspension-brakes-tires-wheels-14/tire-rub-29129/)
I EM 2 4DR. Sep 17, 2006 03:30 AM
tire rub
Has anyone tried an EM2 ('05 4DR.) with 225/40R17 tires on +40mm offset rims, lowered 1.5"? Wondering if I will have tire rub problems after lowering my car 1.5"?
Nail I3unny Sep 17, 2006 09:23 AM
RE: tire rub
205 is the widest tire you can run and not rub without fender modifications.
I EM 2 4DR. Sep 17, 2006 01:31 PM
RE: tire rub
Nail,
Are you speaking from experience with an EM2?
civicexracer Sep 17, 2006 01:48 PM
RE: tire rub
i dunno from experience but i'd think u'd rub with 225...205's should be alright.
coronakid Sep 20, 2006 08:37 PM
RE: tire rub
I have 215/40/17's on an 01 LX and I do not have any tire rubbing. Thats with Tokico and Tein Springs.
MWE Sep 24, 2006 11:51 AM
RE: tire rub
ORIGINAL: I EM 2 4DR.
I claim no expertise with Honda suspensions (I am here trying to sort out a few things for muy wife's '96 Civic and the '07 Civic she is buying), but I have some experience with VWs and BMWs (both street and track). Both are set up with coilovers and adjustable camber (plates in the front and adjustable control arms in the rear). So, some general thoughts: the actual width of a 225/40-17 will depend on several factors. The particular brand of tire (some are wider, some narrower), inflation (obvious) and the specific wheel used. It's not a lot, but a wider width wheel will typically generate a wider actual patch and section width. Most of the tire manufacturers have pretty good spec sheets online that can help you understand what to expect. Front camber will also impact fender clearance; adding a half degree of negative camber can do a lot. Also, you did not mention how much spring rate you are adding as part of the lowering process.
