TIRE SIZE!!
Old Feb 17, 2006 | 03:10 PM
jonyg98civicex's Avatar
Default TIRE SIZE!!
I have a 2dr 98 civic ex, im lowering it in the next month with tokico hp's and tein stechs. I have 17's that i put on when the weather starts to get nice.
I was wondering what kind of tires I should get with the set up that I will be getting. Should i get the 205/40/17 or the 215/45/17? Whats the diffrence between the two!?
Are Kumho's good tires, because I see that i can get 4 ultra performance low profile tires for $200.
Thanks for the Help..
Old Feb 17, 2006 | 03:15 PM
NTX's Avatar
NTX
Default RE: TIRE SIZE!!
ORIGINAL: jonyg98civicex
i've had kuhmos. no complaints, but $200 for four? thats not bad.
Old Feb 17, 2006 | 04:33 PM
riceburner700's Avatar
the difference is the width and the highth in mm
Old Feb 17, 2006 | 08:36 PM
SITNLOW97's Avatar
you will want 205/40/17 or u may get some rubbing ith the others!!
Old Feb 17, 2006 | 08:37 PM
mill$civic's Avatar
205/40/17 is what you want to go with for 17" rims , iv read many people having rubbing problems when going for anything bigger then 40... $200 tho, wow thats pretty cheap for 4 tires
Old Feb 18, 2006 | 01:27 AM
sam@missionspeed's Avatar
^^^^^^+1!!!!
Only stick with 205/40/17
I have been there and done that with the 215/45/17 and you will rub. Good luck!!!
Old Feb 18, 2006 | 01:31 AM
Pete's Avatar
yea 215 will rub, and so will anything above 40ZR.
Old Feb 18, 2006 | 09:43 AM
Mark's Avatar
def go with the 205/40/17. i know someone with an accord with 215/45/17 and they wont even fit on my civic
Old Feb 19, 2006 | 09:09 AM
Alright so ill definately go with the 205/40/17 , but has anyone used KUMHO tires because i wanted to get those kind.
Old Feb 19, 2006 | 01:02 PM
Nail I3unny's Avatar
did you read the entire thread?
