Torque settings?
I was just wondering if there was a specific torque the bolts on the strut towers should be at? I'm installing all 4 strut/bars this weekend and would like to do it right so I was just wondering if someone knew what they should all be torqued at.
Oh also, what about the header? Any specific torque it should be attached to the engine with? Thanks. |
RE: Torque settings?
Yeah it's all in the haynes manual... mine's in my car but I can get you the numbers later if someone doesn't beat me to it
Thanks, that'd be great. I really should pick one of those up sometime.
ORIGINAL: amg6975 Thanks, that'd be great. I really should pick one of those up sometime. |
Good thinkin forty... I just may have to stop by an advanced on my way out of town.:)
Oh, also... The specs on botls required to do the short throw install would be great... incase I can't look it up. |
ORIGINAL: amg6975 Good thinkin forty... I just may have to stop by an advanced on my way out of town.:) Oh, also... The specs on botls required to do the short throw install would be great... incase I can't look it up. hhmmm... i have no idea on that one. I won't be doing mine till next spring, so I have no experience. side note, i went to my car on lunch and it seems i've left my Hayne's at home [:@] |
Hey, no problem, I'm not doing everything unitl tomorrow. I'll check again from home(really crappy internet) tomorrow morn or tonight.
Thanks for the help.:) |
OK! here it is:
front suspension shock absorber to body mounting nuts: 36 ft-lbs rear suspension shock upper mounting nuts: 36 ft-lbs exhaust manifold to cylinder head nuts: 23 ft-lbs exhaust pipe to manifold nuts (d16y8): 40 ft-lbs shifter bolts: not listed. Although in the directions for replacing the shifter it says at the end "tighten all fasteners to the torque values listed in this chapter's specifications." I don't see it there though. Let me know if you need any more numbers! |
You're the man! Well, sorta. I need the bolts for the lower sway bars too. But, I think I'm just going to take a drive over to closest town with an AAP (half hour from here) and pick up a manual tomorrow. I'm gonna look into a thinner head gasket too.:)
ORIGINAL: amg6975 You're the man! edit: my 100th post :). |
