What the benefit of having rear disk brake
Old May 18, 2009 | 01:00 PM
madjoker14's Avatar
Default What the benefit of having rear disk brake
sup everyone, im thinking about doing a rear disk converstion to my 99 civic 2 door,but i just wanted to know whats the benefit of having rear disk brake over rear drums anyways?
would i just need the caliper bracket n pads and just extend the brake line to go into the caliper ? at least thats what my cousin told me.
but do you guys really see any difference with all wheel disk brakes from rear drums??
thanks in advance for any reply's
Old May 18, 2009 | 07:16 PM
intenseneal's Avatar
You need more than that. You will want to get 99-00 Si rear hubs, lines, pads, rotors, discs & e brake cable. I think you can also use Integra parts as well as Si. Having rear dics brakes is a big difference in braking compaired to the small drums. 60-0 will be much better as will braking in and out of turns. Getting drilled or slotted rotors will make a big difference to.
Old May 19, 2009 | 04:49 AM
madjoker14's Avatar
thanks for the info, are the parts easy to come by, and what would i be looking for in parts, labor i can do myself in one of my uncles shop.
im hoping parts would be less then 100 (yea pretty cheap huh lol)
Old May 19, 2009 | 06:41 AM
plethoric33's Avatar
Good luck on getting them under a 100 unless you find an Si or Integra in a Pull a Part.
Old May 19, 2009 | 04:27 PM
madjoker14's Avatar
lol damit!! okay i'll have to price check those b4 i get my hopes up
Old May 19, 2009 | 04:40 PM
Check the local auto wrecking yards for a 99-00 Si or a 94-01 Integra this will be the cheapest way to go. If you can find them, most Honda guys have already picked the yard clean these days. Some online companies sell the swap as a kit from JDM modle Hondas. Expect to pay a bit more for the JDM parts even though they are the same as the USDM. In any case look to spend $250- $350 for parts. It is best to get new rotors, pads and lines and find used hubs and calipers.
EJ8_Man
Feb 23, 2008 01:12 PM
urtoslo
Nov 5, 2007 08:23 AM
TeamExodusPres
Feb 5, 2007 05:29 PM
ahhsimon
Jun 14, 2006 09:52 AM
ahhsimon
Oct 7, 2005 03:11 AM
