What to get
O.k. I know for my suspension I want to go with skunk 2 but should I get there coilovers or lowering springs. Which are better and is there a diffrence.
RE: What to get
Lowering Springs:
Good: -inexpensive -smaller drops mean less camber, so you might not even need a camber kit -Stock shocks Bad: -You're stuck at a certain drop level once you put them on -Inability to adjust means they're the worse choice for any car that might be seeing an autoX course Coilovers: Good: -Ride height adjustablity (raise/lower whenever you feel like it) -adjustablity means they're better for tracks -low ride heights (max. drops of 3.5" to 4") Bad: -expensive -cheap coilovers bounce like crazy -You'll probably want a camber kit -You'll definitely want to upgrade to adjustable shocks I'd say if you live in an area with harsh winters or plan to race your car, get a set of coilovers. If your winters aren't bad and the roads are decent where you live, go with the lowering springs. |
RE: What to get
Thanks for the info. I think I'm going to go with the coilovers. I don't do any autocross but I'd like to find out how to get into it and start racing. Thanks
