wheel size for '07 Civic LX
Old Sep 23, 2006 | 06:03 PM
MWE's Avatar
MWE
Default wheel size for '07 Civic LX
I am new to this forum, so please be patient ...
My wife is purchasing an '07 Civic LX sedan. I am trying to determine if any of my "spare" tires and wheels will fit. When she had a 4x100 Honda and I had 4x100 VWs, I could move tires and wheels around easily. The '06/'07 Civics have gone to a 5 bolt pattern. I was hoping for 5x100 because I have lots of 5x100 wheels for my several late model VWs. I have seen references to both 5x114mm and 5x114.3 for an 06/07 Civic. The latter makes more sense because that is the 5 x 4.5" standard
1) is the pattern 5x114mm or 5x114.3mm ?
The stock wheels are supposed to be 16 x 6.5 but I can find nothing useful on the offset
2) can anyone supply standard ET (offset) numbers for the stock wheel
I want to put snow tires on the car within a month or so. I have some Blizzak W50s in 205/55-16 which should fit the Civic, but need steel wheels. TireRack and 1010Tires both have steel wheels to fit, but perhaps there are other sources
3) can anyone supply a source for "stock size" steel wheels to be used for winter tires.
Thanks for the help
Old Sep 23, 2006 | 06:30 PM
KarTuneMan's Avatar
Default RE: wheel size for '07 Civic LX
It's 5 on 4.5 (114.3)
Old Sep 23, 2006 | 07:28 PM
Remmy's Avatar
im not too sure but they will be the same spec as the 2006 civic.
Old Sep 24, 2006 | 11:39 AM
MWE's Avatar
MWE
ORIGINAL: Remmy
thanks; i would be surprized if the '06 and '07 civics had different wheels (for the same trim level). But that still leaves me asking about the offset for the 16 x 6.5 wheel.
CmonSon
Jul 3, 2010 09:30 AM
civicdude95
Jan 16, 2009 06:46 PM
ltkenbo
Dec 3, 2008 08:58 PM
CivicCrazy
Dec 1, 2004 09:21 PM
zaidomar
Nov 17, 2004 01:06 PM
