1992 Honda Civic Auto-Manual Conversion
I have a 1992 Honda Civic Ex Automatic and i also have a parts 1992 honda civic lx manual. I want to swap the auto for the 5 spd but i'm not sure how to go about it. I'm also looking for a new clutch. Does anyone know if i have to change the cv axle's. I need a lot of help
thanx tim |
RE: 1992 Honda Civic Auto-Manual Conversion
post needs to be posted in the transmission section. but to answer your question,
parts list 92-00 5spd tranny 92-00 shift linkages (d-series exc. del sol) 92-00 pedal assembly(or choose to use only the clutch pedal and cut down the brake pedal) clutch master with resevoir hyd. master lines(lines from clutch master cyl to slave cyl.) slave cyl 92-00 front transmission mount and bracket(auto will not work) 92-95 5spd ecu your factory automatic axles WILL work with the 5spd conversion. ive done this many times and IMO well worth the effort. |
I moved it to the correct section... ;)
~Amanda |
