2002 civic SI
Old Aug 24, 2009 | 08:30 AM
gareth_st's Avatar
Default 2002 civic SI
Hello, I have a problem, everytime i drive in 2 gear and i turn right i hear a clicking noise. its fine in first and third gear. so i took it into honda for them to check and this is what they think/said:
very possible tranny gear problem wiht 2nd gear( gear pack, syncrose) will have to tear down to know for sure. most likely cause is the reverse idler gear contactin the gear hub sleeve set- need to replace the reverse idler gear, the 1st and 2nd synchro hub/sleeve set and the reverse gear holder.
does this sound right?? it only makes the noise in 2nd gear turning right.
thanks!
mr honda
Aug 25, 2007 09:31 PM
Kenneth Ames
Mar 20, 2007 02:42 PM
2002coupe
Aug 11, 2005 03:24 PM
fhsgolfer123
Jan 17, 2005 10:32 AM
OCH Orange County Honda
May 25, 2004 08:58 PM
