2nd Gear Trouble
Old May 29, 2006 | 12:26 PM
trippingbilly08's Avatar
Default 2nd Gear Trouble
I have a 2001 Civic EX and 50% of the time that I put it into 2nd Gear it grinds horribly. Its only when i shift to second gear. If im driving through a parking lot in second sometimes it'll be fine and then all of the sudden it'll grind. I don't know very much about Hondas and I was wondering if anybody could help me out. Thanks.
Old May 29, 2006 | 08:43 PM
mill$civic's Avatar
Default RE: 2nd Gear Trouble
in my 2000 civic it kinda does that to me but only when its really cold out side in winter time,when i posted about this people sead that eather you got to go get it check, or try changing the tranny fluid and using synthetic oil
Old May 31, 2006 | 11:19 PM
riceburner700's Avatar
try chaning your tranny fluid and see if it helps. sounds like the syncros arnt linning up with the 2nd gear and "Grinding" the little dog teeth which isnt a good thing
Old Jun 6, 2006 | 11:30 AM
AgentofDarkness's Avatar
It definatly sounds like your 2nd gear synchro is on its way out. You can try to change the tranny fluid with some synthetic oil b/c that works better. The synthetic fluid is thinner and it will be able to leave the spaces in between the synchros faster than regular oil and might give you a smoother shift.
Juans_MX3
Apr 9, 2010 05:37 AM
EWilliams2000Excoupe
Sep 20, 2007 06:48 PM
ic892003
Nov 25, 2006 07:58 PM
Tram
Jun 7, 2006 10:30 PM
mill$civic
Feb 12, 2006 09:56 AM
