90 Si taller 5th gear swap or overdrive available
Old Jul 29, 2012 | 02:25 PM
drzaeis's Avatar
Default 90 Si taller 5th gear swap or overdrive available
1-4 are great but the car is screamin on the freeway...a 6th gear would be great! is it possible to change the 5th gear ratio to lower rpms' on the freeway?
thanks! Ive already searched for this and was unable to come up with an exact answer...
Old Aug 8, 2012 | 11:18 AM
switch263's Avatar
I'm sure it could be physically done but would most likely involve custom machining work at a minimum. I've not come across any places that sell pre-made gears to change your ratio on a given transmission.
Old Aug 8, 2012 | 12:29 PM
For a D series? Look at a transmission from a 92-95 Civic VX. However, you would be looking to convert to a hydro transmission.
For a B series? It is common to see people install 5th gears from an Integra LS transmission for better highway driving.
Old Aug 9, 2012 | 05:50 AM
drzaeis's Avatar
it's the stock motor. 1990 Si--so a d series...when you say hydro you mean a manual with a hydraulic clutch correct? not an automatic? sorry Ive only owned american muscle before so a hydro is a generally a 3 speed auto trans..
what kind of cost is involved to swap the tranny? is this a junkyard swap or an expensive aftermarket item?
thanks
Old Aug 9, 2012 | 09:12 PM
droopy128's Avatar
you can change the fifth gear on the main and counter shaft, require tear down in the tranny..
Old Aug 10, 2012 | 06:27 AM
thanks
Hydro clutch, yes. Reserach it and you can get an idea of prices. I have never played with 88-91, so I know nothing about them.
brinriha
Jan 3, 2008 01:28 PM
FocusBoy949
Jul 30, 2006 02:55 PM
Whacker1
Apr 13, 2006 05:39 PM
AgentofDarkness
Jul 6, 2005 03:51 PM
spevie
May 27, 2005 08:34 AM
