auto tranny problem
Old Jan 20, 2006 | 11:40 PM
thakid's Avatar
Default auto tranny problem
i have a 1994 honda civic LX with an automatic transmission and i think the tranny is slipping because when i accelerate the rpm's increase but it does not pick up much speed and also the gears take quite long to shift. and i would like to know what is trans-x and does it really work
Old Jan 21, 2006 | 08:05 AM
AOL.COM's Avatar
Default RE: auto tranny problem
first thing i would is change the fluid---if that doesnt fix it --then theres nothing else u can do short of an overhaul
Old Jan 21, 2006 | 05:28 PM
Remmy's Avatar
I think your tranny is trashed. Dont bother getting it fixed. Get a manual swap. It will cost you LESS THAN HALF. Take it from me kid, I found out the hard way. ($2300 for one F!@#ing gear!)
Old Jan 21, 2006 | 06:54 PM
thakid's Avatar
i am definately be swaping it by next winter
i just wanted to know if there was any thing i can do to make it work a little better because i have to go to school and race on the side and got my *** handed to me by a bone stock chevy cavilear
Old Jan 23, 2006 | 02:07 PM
Kappa22's Avatar
Besides something major internally, the slipping and slow shifts as you accelerate could be low fluid or a clogged filter.
Old Jan 24, 2006 | 12:46 AM
my_hidden_romance's Avatar
check the fluids...and stop racing... it kills ur car..and puts a bad name to civics... remmy..where do u get a manual swap...and where does the clutch pedal go?!!?
Old Jan 24, 2006 | 07:37 AM
thakid's Avatar
sence i don't know about automatic trannys were the hell is the tranny filter and how do you change it
Old Jan 24, 2006 | 08:15 AM
Remmy's Avatar
ORIGINAL: my_hidden_romance
Well, source the tranny first. I dont know ALL of what you need but anybody here will tell ya. Sometimes a dealer can do a swap for you but most the time you are going ot need to go to a performance shop to get it done.
Old Jan 24, 2006 | 10:24 AM
i found a guy on here thats in nc that might be able to do it for me
Old Jan 27, 2006 | 06:53 AM
leco516's Avatar
Get a chiltons repair guide to give you step by step instructions.
the filter is inside the pan, remove the pan put in new filter and new pan gasket,fill with new oil. this fixes 90 percent of auto trans problems
