CEl=On D4 Flashing
Old Jan 20, 2009 | 05:03 AM
StonedCold's Avatar
Default CEl=On D4 Flashing
99 DX. It's a tranny out of a 98 EX. Driving down the highway no problems- then they both came on. Any clues or what do I do from here? Still drives just doesn't shift on it's own.
Old Jan 20, 2009 | 05:07 AM
315 Customs's Avatar
Need to check the code for the CEL. Heres a link on how to do it. Once we know the code then it'll be easier to determine what the problem is.
http://www.honda-tech.com/showthread.php?t=878010
Old Jan 20, 2009 | 06:08 AM
StonedCold's Avatar
It appears to flash 7 times. They are a long even flash. The D4 light flashes 8 times.
Did I do this right? There is a AutoZone semi close. Would it help to have them pull the code?
Old Jan 20, 2009 | 06:29 AM
well 7 long flashes (1 second each) would be code 70 which I dont see anything for that code
if they were 7 1/2 second flashes then that would be code 7 for throttle position sensor.
I'm not sure what the flashing D4 light indicates.
Old Jan 20, 2009 | 06:38 AM
StonedCold's Avatar
I know maybe one or two are long. The rest seem to be faster? It's hard to tell.
Old Jan 20, 2009 | 06:39 AM
StonedCold's Avatar
How do you time the flashes?
Old Jan 20, 2009 | 06:41 AM
you should be able to tell when the light starts flashing faster or slower. Its important to know how many long flashes and short flashes there are. Maybe take a video of the flashes if you arent sure and upload and we can determine the code for you
Old Jan 20, 2009 | 06:48 AM
StonedCold's Avatar
ok I'll try the video thing.
When shifting from P to R or D it goes into gear hard. If that helps you figure it out any.
I'll go take the video and come back. soon.
Old Jan 20, 2009 | 06:57 AM
StonedCold's Avatar
ok got the vid.
Where do I upload it to?
Old Jan 20, 2009 | 07:09 AM
photobucket.com
