clutch fluid??
Old Jun 17, 2005 | 12:14 AM
skimmy_jimmy's Avatar
Default clutch fluid??
im new to owning a manual, so im not sure what you put in for tranmission fluid. in the manual it says CLUTCH fluid, what the h3ll is that??
Old Jun 17, 2005 | 12:24 AM
D16z6's Avatar
Default RE: clutch fluid??
Dont know what clutch fluide is but ur suppose to use motor oil for manual transmission and transmission for automatic. I would recommend using Mobil 1 syntec if u have a manual.
Old Jun 17, 2005 | 12:27 AM
ha sorry u gotta keep answerin my questions bro[&:] what would be best tho, i mean like 10w30, 40... ??
Old Jun 17, 2005 | 12:32 AM
D16z6's Avatar
Not sure if it really does matter. I'll let someone else answer this.
Old Jun 17, 2005 | 12:36 AM
alrighty thanx anyway man
Old Jun 17, 2005 | 01:45 AM
young gun's Avatar
whoa! motor oil for mannual tranny? no i think your suposed to use gear lube not motor oil and if it says clutch fluid it probly is for the hydrolic clutch cause there are 2 kinds of clutches cable and hydrolic im not sure but if you don't know go ask someone at a mechanics shop they will know but don't put motor oil in the tranny
Old Jun 17, 2005 | 01:53 AM
haha thanx man! prolly saved my *** right there[&:]
Old Jun 17, 2005 | 08:43 AM
StifflersMom's Avatar
Cat Fuсker
You are supposed to run motor oil in Honda manual transmissions...go check with the dealer, they probably have some special stuff, but I run 5W-30 in my tranny and its perfect.
Old Jun 17, 2005 | 02:42 PM
D16z6's Avatar
yeah thats what I thought too. Your suppose to use motor oil.
Old Jun 17, 2005 | 08:07 PM
sacicons's Avatar
it IS motor oil. 10w-30 is recommended. DO NOT PUT GEAR OIL IN THERE! for the clutch fluid, use brake fluid.
pippo
Jun 16, 2014 12:08 PM
enigma34
May 13, 2009 06:41 PM
weswing04
May 11, 2008 07:46 AM
Cutt
Feb 7, 2006 07:56 AM
Toppers
Feb 2, 2006 01:30 PM
