CLUTCH HELP!?!?
Old Feb 20, 2006 | 08:06 AM
SkItZiAnIsT's Avatar
Default CLUTCH HELP!?!?
I JUST GOT MY CLUTCH REPLACED LAST SUMMER 10K MILES ON IT, ALMOST ALL THE PRESSURE IS GONE, BUT IT ISNT SLIPPING... DO I NEED TO GET IT ADJUSTED, OR A NEW ONE?
ALSO B4 THEY REPLACED IT WHEN MY OLD CLUTCH WAS STILL GOOD THE CATCH POINT WAS VERY LOW, AND THEN AFTER THEY REPLACED IT, IT WAS VERY HIGH, DID THEY DO SOMETHING WRONG?
Old Feb 20, 2006 | 11:31 AM
baker's Avatar
Default RE: CLUTCH HELP!?!?
clutch fluid?
Old Feb 20, 2006 | 02:37 PM
01CivicEX's Avatar
i'm thinkin slave or master cylinder
Old Feb 23, 2006 | 06:12 AM
had to replace it all cuz one of the springs was messed up
Old Feb 23, 2006 | 10:58 AM
StifflersMom's Avatar
Cat Fuсker
check out the firewall next to the clutch pedal...if it's wet, you have a leaking clutch master cylinder. Very common problem. Or it could be a rubber line or the slave cylinder....most likely the clutch is fine
Old Feb 23, 2006 | 03:44 PM
AgentofDarkness's Avatar
I don't know wat the problem is, but full caps is really annoying.
Old Feb 24, 2006 | 07:47 AM
ORIGINAL: AgentofDarkness
i work for an engineering firm, you have to have caps on to work in cad and microstation drafting programs
VXHatchHero
Jun 13, 2010 09:42 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
