d16z6 tranny ?
will an si 5spd tranny up to a d16z6? if so where can i fiind one?
RE: d16z6 tranny ?
what year SI? I dont know if any SI's are D series, and usually trannies arent interchangable between series (B, D, H, K, etc.)
RE: d16z6 tranny ?
Yeah, if you mean Si as in D16Z6.
RE: d16z6 tranny ?
ORIGINAL: Street Sniper Yeah, if you mean Si as in D16Z6. 85-87 SI's = D15a3 88-91 SI's = D16a6 92-95 SI's = D16z6 (your best bet, as it is your same engine) |
RE: d16z6 tranny ?
so the stocktransmission in my 94 ex is an si transmission? or is there a 94 civic si model also. i want the si tranny for its gear ratios. i have the d16z6 and i think my snychro is shot so it would almost be cheaper to buy a newer tranny instead of rebuilding mine
RE: d16z6 tranny ?
The z6/y8 tranny's (EX)are the best D series trannys. Those motors are called Si like in Canada and elsewhere (I believe). The A6 will mate up, but it's cable.
By default, when I see or hear "Si" I always assume someone is speaking of the B16. |
RE: d16z6 tranny ?
both the 94 EX and SI have a z6 in them, not sure how the gear ratios of the two trannies are compared to one another, but the trannys are interchangable as far as i know.
RE: d16z6 tranny ?
^ It's the same car. The transmissions are the same as well.
RE: d16z6 tranny ?
ORIGINAL: FlipHKD720 what year SI? I dont know if any SI's are D series, and usually trannies arent interchangable between series (B, D, H, K, etc.) sry for the threadjack, just had to point out |
RE: d16z6 tranny ?
Umm, what? You are gonna use your D tranny with an H22? or maybe a GSR? I would like to see that.
