Help Changing ATF and Filter...
Old 11-24-2010, 04:36 PM
mattknapp20's Avatar
Question Help Changing ATF and Filter...
I have a 2005 Honda civic Coupe with an automatic transmission. I looking to change the fluid and the filter. How should I go about changing it, and where is the filter. Also which fluid should I use.
Thank you for the help
Matt
Old 11-25-2010, 06:49 PM
BurningRubber's Avatar
I'm 99.9% positive the transmission filter is inside. So you couldn't change it unless you took it all apart. As far as changing the fluid just empty it and replace. I know my 1998 LX auto has a dip stick similar to the oil stick and you simply fill until its in-between the two lines.I would use Honda ATF fluid.
Hope that helps, welcome to the forum.
Josh,
mundy5
06-16-2014 12:11 PM
DeanHensler
01-09-2012 08:06 AM
txedomask433
08-03-2007 06:09 PM
civic^2
08-22-2006 10:46 PM
Auto98EX
10-07-2005 06:49 AM
Quick Reply: Help Changing ATF and Filter...
