Problem wiith the shifter.... HELP
I have a question when I am driving my 5 speed I can klet off the gas and push the stick and it will go into neutral, is my car supposed to do that or is my clutch or something messed up. If so then should i not do it anymore.
what rpm's are you at when you do this? sometimes if you are at a high rpm the shifter will pop into neutral really easy.....how hard is it to get it into neutral?does it grind or make any weird noises?
you probably shouldnt, but its not a huge deal. it COULD wear on the synchros a little bit faster than normal, because theres still a little torque being put to them as they slide out of place. but just dont do it a lot. sounds nomal though.
most of the time my car is in neutral and I usually take it out of gear w/o clutching. No grinding and it slips out without any force. To me this is just a driving habit and I don't see how this is killing anything
