Project
Old Feb 16, 2009 | 11:26 AM
knowledge_is_power's Avatar
Default Project
Hey, since I moved to vancouver and now have practically no use for a car, I decided to retire my 1987 Civic 4wd. Then i thought, this car is sweet, and with the acura swap job, it rips. I decided to keep it as a project car, and, since it has such a perfect wheelbase, slowly reinforce the frame (beefy as it already is) and replace components turning it into a rally machine. Now, haynes is super unclear as to how the 4wd system works (its a wierd rear differential system) and ive been trying to figure out if i can make the 4wd system manually engaged. (eg, manually locking diff) there, apparently, is some sort of electrical system also associated with the 4wd, and although i havent spent alot of time on it yet, i thought id ask here first. anyone heard of stuff like this?
tl;dr: the 87 5dr 4wd rear diff: can I make it manual?
Old Feb 18, 2009 | 03:54 PM
lancerswimmer89's Avatar
pics?
Old Feb 18, 2009 | 08:22 PM
jpnolan's Avatar
This has been done before. Google it. Prepare yourself for a hole lot of work. But if you do it right it will all be worth it. Good luck to you sir and welcome to HCF.
2ND2NO1
Dec 9, 2004 10:25 PM
dalifts
Nov 15, 2004 08:59 PM
sacicons
Oct 27, 2004 08:25 PM
Importman04
May 24, 2004 10:18 PM
vipervail
Apr 29, 2004 02:06 AM
