HondaCivicForum.com
-   Transmission & Differential (https://www.hondacivicforum.com/forum/transmission-differential-39/)
-   -   shifting into reverse problems (https://www.hondacivicforum.com/forum/transmission-differential-39/shifting-into-reverse-problems-4765/)
mill$civic Apr 18, 2005 03:28 PM
i just got a 2000 civic about 4 months ago or so, i have noticed that i have real trouble sometimes when i try to put it into reverse, its like it dosent want to get in reverse and if it dosent get into reverse and i let go of the clutch,it grinds,i have to try like 5 times sometimes to get in in reverse...anyone help? it this a problem with the tranny?
StifflersMom Apr 18, 2005 04:48 PM
RE: shifting into reverse problems
Do this: when it doesn't go into reverse easily, let go of the clutch with the stick in neutral, press it in, wait 5 seconds and voila. Should work.
finalimpact Apr 18, 2005 04:53 PM
or with clutch depressed shift into 1st then 2nd and go straight to reverse. works like a charm for me.
StifflersMom Apr 18, 2005 07:48 PM
Yea, that too
Forty04 Apr 19, 2005 08:14 AM
on a side note, do your cars make a funny noise while in reverse? like wumwumwuwumwum... gradually getting faster? Mine just doesnt sound as smooth as i expected i guess
StifflersMom Apr 19, 2005 09:34 AM
Yea it does. I think all standard cars sound like this in reverse.
mill$civic Apr 19, 2005 09:59 AM
ya ,im sure all standerds sound like that when u reverse, but thanks for the tip, so this is not anything wrong with my tranny then??? or is that just the way it is?
Forty04 Apr 19, 2005 10:30 AM
alright cool, just makin sure! thanks!
LEVIII Apr 19, 2005 10:31 AM
It makes that dumb noise in reverse because your reverse gear in the transaxle are straight cut and not cut at an angle. If you ever hear of a dog box tranny, they are synchroless trannies all gears are srtaight cut and they whine like that in every gear.
Shifting into first will do the trick because you are lining up the synchros.
frewcivic Apr 26, 2005 09:52 PM
you probablly would get a kick out of seeing an actual trany dissasembled
