si trans any better than cx?
Old Feb 21, 2006 | 09:16 AM
jusplayn85's Avatar
Default si trans any better than cx?
I'm looking into putting a stage 1 clutch in my car. (d15b8 block) I've heard a few different places that the SI trans is better than most. Is this out of any si? Or just from a del sol. As long as it's a d-series it should bolt up, I'm just wondering if it'd be worth it to do the trans swap with the clutch. Thanks
Old Feb 21, 2006 | 09:23 AM
antrmo's Avatar
Default RE: si trans any better than cx?
ive herd that si trans are good if you like to drive ,,short gear ratios (i think) which would make sense since the si is the sporty model ..
Old Feb 21, 2006 | 09:38 AM
jusplayn85's Avatar
ORIGINAL: antrmo
Hell yeah I like to drive... lol. I like my gears like I like my women.... tight. Anyways... sounds like a good swap to me.. along with the shortthrow I got the other day. Thanks for the info.
Old Feb 21, 2006 | 01:22 PM
jusplayn85's Avatar
I've been looking into it, which trans would be better. For a d15 or for a d16 vtec? or are both transmissions the same for the si?
Old Feb 21, 2006 | 01:33 PM
ef4life's Avatar
the si has closer gear ratios which allow for faster acceleration and are good for high rpm n/a motors. longer gearing like a cx trans is for better economy and a broader power band like in a turboed car
Old Feb 21, 2006 | 01:48 PM
jusplayn85's Avatar
So I'm definitely goin with the si trans. So would that be the d16z6 vtec trans or the d15b... vtec trans? or would they be the same? Sorry if i'm confusing myself..
Old Feb 21, 2006 | 02:34 PM
Nail I3unny's Avatar
the EG si was a z6
Old Feb 21, 2006 | 02:39 PM
dj_ipirate's Avatar
wouldnt an ex tranny be just about as good?
Old Feb 21, 2006 | 06:34 PM
ef4life's Avatar
i believe a jdm d15b tranny came with an lsd so that might be worth checking into
Old Feb 21, 2006 | 07:13 PM
dj_ipirate's Avatar
are you sure? i herd at hond's launch of the new si, that this is the first time lsd has came with a civic
