Slight grinding on shifts!
I have noticed that sometimes when I shift, I can here a slight grinding noise. Could this be worn syncros, or maybe it just needs the oil changed? I dont know? I happens quite frequently.
RE: Slight grinding on shifts!
Throw out bearing normally squeaks or hums. It makes a constant noise that should vary depending on if you have the cluch in or out. My guess is either tranny oil(which should be really cheap to change just a few bucks if you do it yourself) or syncros. If it is the syncros just look for a good used tranny on e-bay or something. They run abou 200 bucks. I got mine for 150 plus 80 shipping and replaced it in 1 afternoon.
I don't think tranny/motor mounts will give you a grinding noise. When mine were worn I would get a click/clunk noise when accelerating or decelrating/stopping. The engine would wobble back and forth depending on strain.
grinding is most likely a syncro & or gear problem ----either way its internal ----the only thing u might want to try --is change the gear oil & try synthetic gear oil --maybe u will get lucky
Well, I changed the oil last weekend. I put Amsoil 10W40 in it. There was very little traces of metal shavings in the old oil. I noticed that the old oil in it smelled alot like gearoil. Im not sure if the pervious owner ever changed it or what. Anyway, it seemed to shift a little better for the following next three days after I changed it. Now it shifts great! Alot smoother, and it dosn't grind at all anymore! I guess I did get lucky? Thanks for the post guys!
-Greg-
-Greg-
rsboy
07-16-2007 11:28 AM
