tranny
I just got an engine and 5 speed tranny to replace the one in my 91 civic. The existing one is a 4 speed. Would it be possible to use the 5 speed tranny, and what all is involved in changing it. Is the clutch different?
Thanks in advance Wendy |
RE: tranny
Yes, you can use the 5 speed in place of the stock 4 speed. It doesn't require any kind of conversion or extra parts. Same clutch, same axles, same everything.
RE: tranny
Any tranny that fits on a honda civic will fit doesnt matter wat speed 4, 5, or 6
RE: tranny
That will make things go alot easier. Thanks
RE: tranny
Any tranny that fits on a honda civic will fit doesnt matter wat speed 4, 5, or 6 |
RE: tranny
RE: tranny
what all do i need to a 5 speed conversion/ or manual tranny conversion in general. i have a 4th gen...this is what i have gatherd is there anything else?
break and clutch pedal assembly clutch cable shift linkage transmisson full clutch/ p plate ect. axels is there anything else i need? |
RE: tranny
something easy to overlook, do you have a shifter? if not, look into one froman old prelude. 88 or somewhere thereabout. my friend used to have one in his crx. it was nice, it was shorter than most aftermarket shift throws and had a nice handle. i think it bolted right up with the boot and everything.
RE: tranny
cool...u think thats better then like a sk2 short shifter or sumthing of the such?
RE: tranny
i liked it.. try to look at one and see if you like it.
