Transmission Problem maybe?
Old Feb 18, 2007 | 12:51 AM
lin's Avatar
lin
Default Transmission Problem maybe?
My car only recently started to give me alot problems. Two weeks ago it just clunked out on me, It won't accelerate (does not go past 20), why is this???If it was a tranmission problem wouldn't it not accelerate at all? It doesn't make any knocking noises or anything, doesn't overheat either.....whatis the problem (2001,honda civic ex-automatic)
any suggestions, and the most important how much?
-lin
Old Feb 18, 2007 | 02:50 AM
blackmetal619's Avatar
Default RE: Transmission Problem maybe?
hmm...check for a slipping transmission, also check the transmission fluid level and condition. If the fluid gives off a burning odor, then the transmission has been slipping internally..
Old Feb 18, 2007 | 02:23 PM
riceburner700's Avatar
check the tranny fluid with it running! if its black and you had it changed all the friction material could of came out with the fluid. if its starting to turn dark then get it changed
tuboflard
12
Sep 7, 2012 06:25 AM
nolan1964
14
May 25, 2009 06:04 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
unreg
Dec 10, 2004 10:03 PM
