Take turns with confidence with the most popular performance tires at CARiD!
It doesn't mean a thing if you ain't got good tires. Except for their most obvious function to connect your Honda Civic to the ground, they are responsible for maximum road grip, ride quality, wet and dry handling, high-speed stability, and overall performance of your ride. Whether you’re driving on the highway or competing on the track, installing a set of performance tires onto your Honda Civic is a great idea.
Performance tires are designed to enhance safety, especially when driving at high speeds. They are designed with a sticky, low-rubber compound to improve the level of stiffness and heat resistance. If you are in the market for new performance tires for your Honda Civic, check out our list of the most popular options among CARiD customers.
#1 Michelin Pilot Sport
https://www.carid.com/michelin-tires...us-468119.html
Features:
- TriFusion compound to elevate your vehicle’s performance in all types of weather
- Designed to deliver better wet handling than leading competitors
- Advanced MaxTouch construction to ensure even wear and long-lasting service
#2 TOYO Proxes
https://www.carid.com/toyo-tires/pro...-55236874.html
Features:
- Silica-reinforced, high-grip tread compound
- Refined unidirectional tread design
- V-shaped main grooves
- Rigid shoulder rib-bands
#3 BFGoodrich G Force
https://www.carid.com/bfgoodrich-tir...2-1248746.html
Features:
- Sport Design Tread delivers sharp steering response in wet and dry conditions
- Equal Tension Containment System maximizes the contact patch for better stability and wear resistance
- Dynamic Suspension System reinforced internal structure increases ride comfort
- g-Control sidewall inserts add sidewall stiffness to resist deflection for immediate turning response
#4 Bridgestone RE71R
https://www.carid.com/bridgestone-ti...-65486393.html
Features:
- Asymmetric Construction
- Tread Compound
- Large Outer Tread Blocks
- Hydro Evacuation Surface (H.E.S)
When is it time to replace my tires?
Find out in our tech article! https://www.carid.com/articles/when-...-my-tires.html
Ds108
Dec 21, 2019 11:04 AM
specialk
Apr 15, 2008 03:51 PM
pass1over
Dec 3, 2006 09:30 PM
