2004 wheels fit 1994?
Old 03-18-2008, 04:45 PM
vtnomad's Avatar
Default 2004 wheels fit 1994?
Will 15"x6" wheels off of a 2004 Civic fit on my 1994 Civic EXcurrently usingstock 14"x5.5" wheels? Both are 4 lug pattern. Is there only the 4x100mm pattern, or are there other patterns that would cause these wheels not to fit my car? Thanks.
Old 03-18-2008, 04:50 PM
Default RE: 2004 wheels fit 1994?
not an answer to ur question but just thought i'd let u know... changing the radius to ur tire will make ur speedometer inaccurate... there was a calculator out there somewhere to show how off it'll be... just wanted to give u a heads up =)
Old 03-18-2008, 05:09 PM
vtnomad's Avatar
Glad you mentioned that. I was aware of it, but it completely slipped my mind. I have no idea what size the tires are, I found the wheel/tire combo on Craigslist and the seller didn't list the tire size. I use this tire calculator http://www.miata.net/garage/tirecalc.html. I don't imagine it will make too much difference, there is a limit too how big a tire you can stuff in the wheel well, and how small a wheel/tire you can fit over the brakes. My current setup and new setup are both stock, so I'm not expecting anything extreme.
Old 03-18-2008, 05:52 PM
TheJGB3's Avatar
All Civics from 1985 to 2005 are 4 on 100MM. So the wheels will fit. As for a +1 tire fitment I would run the 99-00 SI size P195/55R15.
Old 03-18-2008, 06:30 PM
2003-2005 civic si's are 5 lug so they won't work
Old 03-18-2008, 06:56 PM
bakertime's Avatar
Si wheels won't work (Unless it's the 4 lug version from certain ep3's...maybe the 02s), but alloys from an EX, LX...etc would be fine. Double check the offsets too in addition to what tire size you'll need. I think all Honda wheels are +45, but it wouldn't hurt to double check before you spend the cash.
hankd
03-02-2008 03:54 PM
Pete
01-19-2008 12:28 PM
briank94
06-28-2007 08:51 AM
shikoz
04-11-2007 04:51 PM
TheGodfather
06-08-2006 12:38 PM
Quick Reply: 2004 wheels fit 1994?
