antifreez leaking?
antifreez leaking?
hey, ok well i noticed this morning when i was leaving the house there was some dots of antifreez on the ground in the snow, i havent driving the car for 2 days before that..so i took it to my guarge and took a look and couldent see anything, so i let it run with the heat on for like 5 min and nothing..so i took it out of the guarage and parked it over snow and let it run for 10 min with the heat on..nothing on the ground. why would it only happen once? or is this normal once in a wile?
thanks
thanks
RE: antifreez leaking?
have you done anything to it recently, where you might not have tightened a hose?
my truck was leaking, but ALOT...it was right at the t-stat housing, and it turns out that with the very cold weather here, with the expansion and contraction of the hose material, it leaked...
do you see any moisture anywhere under the hood?
hey, no i havent done anything to it under the hood latley, there is mosture but just from water and snow..i looked for antifrez on hoses and such but couldent find anything
im not sure if this is it...but before that i got stuck in my driveway because we have lots of snow, so when i backed up alot of snow got built up behind my front bumper agenst the rad and fan..mabey it was because of that?..i keep checking and nothing
