Compression test results (good or bad?)
So here's the results:
1. 159 PSI
2. 154 PSI
3. 151 PSI
4. 156 PSI
Service manual says should be 135 PSI.
My car has 103,000 miles it.
Why is the compression higher than the book says?
1. 159 PSI
2. 154 PSI
3. 151 PSI
4. 156 PSI
RE: Compression test results (good or bad?)
Try running some seafoam through the engine or something else that will reduce the carbon deposits. As long as the readings are within 10% of each other you don't have any major problems.
TheInternet
01-22-2008 01:34 AM
ErikElvis
03-18-2007 04:21 PM
