does this sound right 1/4 mile times
Old 06-24-2008, 12:07 PM
scottdh20's Avatar
Member
Default does this sound right 1/4 mile times
i have a 95 civic hatch cx
d15b7:
d16a6 cam
aem true time set to 3 deg adv. = 2degrees retarded based on the camshaft being 5 deg off
d16a6 valve springs
head was resurfaced and inspected by napa
motor rebuilt 400 miles ago- new pistons, pis. rings bearings all gaskets, water pump, oil pump,ect
aem short ram intake
dc sport headers
2.25 exhaust headers back-no cat
skunk2 exhaust valves
new oem intake valves
had pass. headlight out for direct airflow to filter
16in rims with good toyo proxie fz4's 40psi
lowered 2.5 in
gutted exept 2 racing seats, dash and door panels
no ac
rack and pinoin steering
ngk iridiums
probly has a couple other little thing i cant remember
it ran consistantly 16.8
best was 16.5
reaction times were all in the .2's
from what ive been reading i think it should be faster
i have a si intake mani that should help a bit
i thought i would be low 16- high 15's
Old 06-24-2008, 12:08 PM
scottdh20's Avatar
Member
Default RE: does this sound right 1/4 mile times
rebuilt 4000 not 400 miles ago
Old 06-24-2008, 12:49 PM
cyberx32's Avatar
You have the cx, it has the longest gearing, so its not gonna go too fast
Old 06-24-2008, 09:46 PM
^+1
and do a mini-me swap and your times will get a little better.
Old 06-25-2008, 04:01 AM
scottdh20's Avatar
Member
IT HAS A DX TRANNY AND MOTOR, I SWAPED IT IN WHEN I FOUND OUT THE DUECHE THAT SOLD ME THE CAR FORGOT TO MENTION THE 3 HEAD STUDS HE SNAPED DURING A HEADGASKET CHANGE. I HAVE AN SI TRANNY BUT I COULD NOT GET THE BELL HOUSING OFF THEY GUY WHO TOOK IT OFF DIDNT KNOW THAT THE STARTER BOLTED TO THE BLOCK SO HE ENDED UP CRACKING THE BELL HOSING TO GET IT OFF. IT WAS FREE SO I FIGURED I COULD TRY TO FIX IT WITH THE BELL HOUSING OFF THE CX TRANNY IN THE GARAGE
Old 06-25-2008, 04:06 AM
scottdh20's Avatar
Member
AND I DIDNT WANT A MINI-ME COMPRESSION WOULD BE TO HIGH FOR BOOST PLUS VTEC IS SEMI-POINTLESS UNDER BOOST. I HAVE A VORTECH SUPERCHARGER THAT IM TRADING FOR AN ENTIRE DSM TURBO SETUP WITH A 16G I STILL HAVE THE CX EXHAUST MANI SAME AS THE HF I THINK EITHER WAY I CAN MAKE AN ADAPER PLATE FOR IT
I JUST WANTED PRE-TURBO TIMES. I WANTED TO PHYSICALLY SEE THE GAIN, FEELIN IT IS FUN BUT BEING ABLE TO SEE ON PAPER WHAT YOUR HARD WORK GOT YA JUST MAKES IT THAT MUCH BETTER
Old 06-25-2008, 06:30 AM
scottdh20's Avatar
Member
nobody has any idea if that sounds right or if it sounds slow. also does any1 know any ghetto fab soultions to eliminate or reduce wheelhop other than traction bars. im saving for them now after the track. god it was like i was going offroading on the launch
Old 06-25-2008, 08:40 AM
cyberx32's Avatar
Well the launch is a big thing, but that still sounds about right for a d series motor. You wont see anything too major until you turbo
Old 06-25-2008, 09:51 AM
scottdh20's Avatar
Member
WHAT KIND OF GAIN DO YOU THINK I WILL GET REALISTICALLY WITH BOOST ON THIS SETUP 6LBS. ON A ROUGH STREET TUNE. THEN ONCE I GET IT OUT TO THE DYNO SHOP WHAT DO U THINK I SHOULD GET. HP NUMBERS AND 1/4 ESTEMAITES. I DID SOME DIGING AND THE STOCK SI DOES A 16.8 SO AM I RIGHT AROUND 130HP NOW?
Old 06-25-2008, 09:54 AM
ORIGINAL: scottdh20
i'm not sure about the numbers, but i think you could easily run more than 6lbs of boost since your engine is like completely rebuilt.
Quick Reply: does this sound right 1/4 mile times
