engine burns oil. help
Old 02-06-2008, 09:01 AM
legal's Avatar
Default engine burns oil. help
2 quarts of oil every 2 weeks how do i not make it burn so much?
Old 02-06-2008, 09:18 AM
BustedSony's Avatar
Default RE: engine burns oil. help
ORIGINAL: legal
Rebuild the engine, your valve stem seals and piston rings are gone.
Old 02-06-2008, 09:21 AM
Cyphen's Avatar
What kinda engine do you have, if its a d15b7 or d15b(The vtec one) check the pcv valve is in all the way. where is it? simpleallign your self dead center with the car with hood open look directly inbetween intake manifold there is this round object looks likea o2 sensor, if its not that this could be signs alot of things after running your car open oil cap lid and see if thier if white smoke this indicates blow by, means piston rings could be takin a **** etc... just so many things make. also make sure your oil drain plug is in tight.. lol my brother left his alittle loose
Old 02-06-2008, 11:18 AM
legal's Avatar
its a 95 civic hatch with a mini me swap in it has 126k miles on it skunk 2 exhaust
Old 02-06-2008, 05:38 PM
cyberx32's Avatar
Might be the headgasket, or its all going into your coolant
Old 02-06-2008, 06:39 PM
Are you getting smoke out the exhaust? If so, what color. If it's bluish in color, your probably will need an engine rebuild to replace piston rings and valve seals. If it's white, it could be a blown head gasket. It it's been maintained as the factory recommends, it shouldn't be burning oil this soon....unless the engine has been really abused and not serviced at recommended intervals.
DaysOfNoah
06-17-2013 09:13 AM
jramuz
08-11-2009 10:01 PM
oilltd
06-10-2008 04:06 PM
Fiirkan
08-17-2006 07:31 PM
Quick Reply: engine burns oil. help
