Engine Question
Old 08-09-2009, 03:26 PM
1990hondacivicex's Avatar
Default Engine Question
I have the D16A6 in there now, does not say anything about vtec, the 16 valve honda motor. Wondering how good is the block is it worth doing anything to or just saving up for a swap ?
Old 08-09-2009, 03:45 PM
depends on what you what and expect....and how much you want to spend
Old 08-09-2009, 05:12 PM
Correct me if I'm wrong, but I don't believe the A6 is vtec. If I'm correct, it's more or less the Z6, minus the whole vtec thing.
As far as if it's worth it, what are your goals? If you just want a moderately powerful (200whp) or so street car, it's absolutely a good block. Forged internals and a Y8 head swap, and you have an amazing engine for boost. Now, if you want a 500whp monster, you're going to want a twin cam.
Old 08-09-2009, 06:22 PM
hamorhead's Avatar
i have the D16A6 in my crx si and i can verify that it is non-vtec
Old 08-09-2009, 08:13 PM
my friend has one turbo'd the pistons in d16a6 are low compression pistons...
Old 08-10-2009, 05:06 AM
hamorhead's Avatar
hows the turbo'd d16a6?
im gonna be doing that........eventually
Old 08-10-2009, 06:16 AM
it runs strong.. its stock with a thick head gasket installed and its on 8lbs of boost..
with a t25 he has had this car for 6 yrs with same engine and turbo'd.. he had it converted to obd1 and a jspec ecu but thats about all thats been dont to it..
Old 08-10-2009, 06:01 PM
Yes I know it is not the vtec and I was just looking for 200-250 hp. As I was wondering if it would be good to boost it and do things with it since it is not the vtec ?
Old 08-10-2009, 06:20 PM
hamorhead's Avatar
boosting on stock internals will get you to 200whp on a good tune
if you want more power you will have to build the d16a6
if you change your mind and decide to go NA please do a swap trying to build a NA dseries will just be a waste of your money and time and leave you wanting more power
Old 08-10-2009, 07:26 PM
If the engine is in good condition you can safely make ~225 WHP or a little more on stock internals with a good tune. The key is in the tune.
Do a compression test first to gauge the health of your engine!
Quick Reply: Engine Question
