Handling or Power?
RE: Handling or Power?
Yeah, its a step up from the HPs. But if your not doing AutoX then I doubt your really gonna need them. I have HPs on mine and its a blast to drive around town. If your still stuck, ask MXS about it. She is the suspension GURU around here.
You don't really need to upgrade the brakes. All I would do for the brakes is get better pads (Hawks FTW). You don't need to upgrade the calipers or anything. You might want to look into a rear disk conversion. It costs like $300 + labor.
well doing a K20 swap def. cost much more than suspension, brakes, wheels/tires put together(unless ur getting some ridiculous baller stuff which isnt necessary). if all ur doing is drag racing, do the swap thenget a decent adjustable suspension setup, some hawk hps pads and blank rotors will be just fine for braking, and w/e wheels/tires.
ORIGINAL: AgentofDarkness
ORIGINAL: windcalmer
The reason I said rotors is because of the age of the stock rotors. If they have been machined a few times, then they are getting on the thin side. And you can get some Brembo rotors for cheap. It just cuts out more work later on.
stick only
14
12-01-2005 08:35 AM
